A few split port questions
jwhisl
Oklahoma
So I'm in the middle of my split port swap. Heads are already on the car. I've got an upper and lower intake from a 2002 mustang. I'm going to remove the IMRC. I read that I may need to use the injector harness from the 02. Is that correct? I got the tb and all the sensors from the 02. I also got the throttle cable. What else do I need?
J
jwhisl
Oklahoma
330CubeGt is the only one I know of who has done the swap
I know [MENTION=12985]warthogdriver[/MENTION] wrote up the fuel rail tutorial in the how to section. I drilled out the screws on the butterflies for the IMRC and removed them.I also used the tutorial to make my own fuel rails. It was very helpful. I'm going to use the 02 wiring unless someone says I shouldn't and just splice in anything that doesnt match up. Especially since I want to use the newer injectors.
J
jwhisl
Oklahoma
Just in case anyone else wants to do this swap. Save yourself some time by using the 95 harness and buy a set of injector adapters from latemodelrestoration.
