ABS Sensor - Front
vermilion
maryland
Either a 1/4 or 5/16 starred socket. 1 bolt with some wd40 and scrape excess road grime. It should ease on out. Its on the spindle hub.
O
I could only get the bolt out on the one side... after removing the bolt it was still really solid in there so i started to gently pry at it and next thing i know the part by the bolt snapped off and the rest of it is still stuck through the hub.
O
Turns out tapping them out from the other side is the way to go, much stronger that way. chalk it up as a learning experience, at least it isn't an insanely expensive part.
Jerry santos
