Advance Timing
BlackCobra50
I've read that if you advance (bump) your timing, you gain about 3hp and it runs better. How do you do this?
CA.
95-stang
You reset the timing, instead of the factory 10 degrees before top dead centre, using a timing light you slowly rotate the dizzy until it reads 12 at the pointer, or you can aim for 14 though some cars suffer from pre-detonation at 14 on standard pump fuel so if you hear it pinking back it off to 12.
In fact just try it at about 12 first it can add a little performance.
Timing is easy and you will pick up alot of throttle response, get a timing light, with the car off pull the SPOUT sensor which is located near the MAF wiring on the passenger side fender. Loosen the hold down bolt, start the car and use the timing light to set the timing on the harmonic balancer to where you desire. Best is to go to 12 degrees, drive the car and see how it works out, then go up to 14. Also remember that when advancing the timing you will increase the risk of detonation if not careful with how much you increase it. Run a little higher octane fuel as well, go to 89 or 92/93 what ever you have in your area. *You have to put the SPOUT back in, in order for the ECU to keep the new timing setting*
B
BlackCobra50
What does the "spout" look like? Any pics of it?
94kingcbra
Wondering how to bump up your timing? Here ya go!
1. First things first. You'll need a few things: a timing light, a distributor wrench or a ratchet and socket that will fit the distributor hold down bolt, and a little know how.
2. The first thing you'll have to do is disconnect the spout connector. Make sure the car is off when you do this. On 94-95's its near the passenger side strut tower(B). The reason you disconnect the spout connector is so the computer doesn't automatically change the timing when you move the distributor, which will let you set the base timing. Oh and whatever you do....Don't lose the spout connector.
3. Next you'll have to connect the timing light. With most lights you have to connect the positive and negative clips onto the positive and negative terminals on the battery. Then you clip the inductive lead of the timing light onto the number one (1) spark plug wire. If you are standing in front of the car looking at the engine its the first spark plug wire on the left side of the engine.
4. The next thing you will need to do is start the car. Before you do so there are a few things to look out for. First make sure there aren't any wires hanging near the belts, pulleys or fan You'll also want to check to make sure you can see the actual timing marks on the harmonic balancer. Some times is easier to get some whiteout and crawl under the car and mark where you'd like the timing to be set at, such as 14 degrees.
5. Before you start the car, loosen the distributor hold down bolt(D). Don't take it all of the way out, just loosen it a little. If you take it all of the way out the distributor gear may skip timing when you start the car up, which isn't a good thing.
Now start the car, and point the timing light at the timing marks(A) and pull the trigger (if it has one). You should see the light flashing on and off, and you should be able to see the timing marks, or the one mark that you made with the whiteout. Be careful, don't let the timing light, or even worse your hands get caught in the belts or hit with the fan.
6. While holding the base of the distributor (not the top near the plug wires) turn it very slowly until you get the timing where you want. Then tighten the distributor hold down bolt and re-check the timing to make sure the distributor didn't move. Don't forget to re-connect the spout connector too.
7. There you go! You're all set!!! There are a few things you should know. Ford set the timing at 10 degrees from the factory so you could use low octane fuel. If you bump up your timing then you'll need to use a higher octane fuel, usually 91 octane. Although I've seen and heard of people running 18 degrees of timing without having trouble its really not recommended. When you set your timing too high your engine will ping, which will cause bad things to happen like blown pistons.
Try setting your timing at 13 and take a ride. If it doesn't ping then you can try setting it higher, but once it starts to ping turn it back down a degree or two. Basically what we are saying is be careful and, if you don't under stand any of this have someone who does help you.
[attachment deleted by admin]
Venom351R
Maine
you will have to run at least 91 or 93 octane if you bump your timing depending on what you have in your area. Advance it until it pings and then back down a degree or two
if you go buy a haynes or chilton manual you will also have a written step by step directions on how to do this with pics
