mike012v
Was thinking about doing a t-56 swap in my heads/cam 2v before i put everything back together. whats the advantages over the t-45? except for the extra gear of course. any input would be great!
The 3650 is 120 lbs dry, the t5 is roughly 95 and a t56 is 135. Like I said not much difference to really whine about but between added weight and cost its up to you to decide if it is worth the cool factor IMO.do u know how much more it roughly weighs? and what other negatives come with it besides being heavier??
I heard from 1 person that it shifts so smooth but he didn't drive a stang either... but good to know its not too noticeable
This is about a common a debate as Trick Flow vs AFR... many opinions, many facts and no real clear answer. I say this because there will always be outliers and factors that make arguments on both sides irrelevant. I had a factory 100k mile t5 and clutch trapping 125 mph... other people blow them with factory power. Its all a matter of how you drive regardless of trans and I suggest getting what you want based around assumed future power levels. When my t5 started whining from years of abuse I replaced it with a 3550 and never looked back. Regardless of ratings, I will say again, it is how you drive it....yea i think it has a lot more benefits to to worry about 40lbs... the price and what onyx said.. it being louder, may shy me away... know any other transmissions that can hold 450-500 to the wheels? now is a good time to start my research lol cause i know my t5 cant
Ive driven several and it does have a lot to do with the gasket between the floorboard and shifter selection. Currently the one I use is a pro 5.0 and it got quite a bit notchier and louder. Factory it wasnt terrible, but yes it was definitively louder than the t5's I have owned and currently do own.I wish I could give you definitive input on my T56 loudness, I apparently installed it wrong so that could be why mine is making excessive noise. Obviously shifters and gaskets make a difference in how much noise you hear too. Pretty sure the T5 is around 80 lbs but regardless the weight difference is not a big issue, i had more trouble with the massive size of the T56.
One reason I went with the T56 is because I heard TKOs were loud and notchy, apparently some T56s can be too. But i'm hoping its because of my improper install that i'm getting the excessive noise and notchiness from.
I dont know exactly how much power you are making, but you will certainly put any trans through the test with those conditions. I recommend a tko600 but thats just me.ok, that is definitely helpful... i mean i have the turbo in and the power already... upgraded my clutch before the turbo ever went in... i don't go to the track to to much but i think this year that is going to change now that i have what i have... and im probably gonna come out the hole anywhere from 3500-5k rpms... and with the linelock doing 3rd-4th gear burnouts before staging... tranny has 175k on it.. few times a year could it handle those kinda drops? and other thing is.. honestly since i have 3.73s.. i may either keep them or go to 3.27s.. but with that and my MGW short throw.. i probably would like to have a tranny that those can just switch over with as well ya know?
I apologize, I may have been to quickly to throw a recommendation out there. Budget, availability of car being down and power needs always play a factor as well. A tko600 will require a new clutch as it is a 26 spline input vs the factory 10 spline. It is very much a sturdy trans that is rated beyond your current power level. that said, a tremec 3550 would technically be enough to handle your power should you treat it right, but I tend to want to play it safe if I am spending the money on upgrading. As far as your rear gears that is completely up to you and another deal I would deal with outside of this thread and focus on trans first.460... and would the shifter and gears all transfer over with a tko600?
That said, is this your dd? What is your budget?
