AFR Ratio
schacher94gt
Does anyone know what the air fuel ratio on our stock 5.0s in WOT? I found that at cruising its 14 to 1, but haven't found anything on WOT. Can I just get a AFR regulator or do I have to dyno tune it, to change my ratio?
Ideally you want 14:1 through out the rpm band. or just a tad on the rich side.
A tune would be the best way to get 14:1
IceMan
Normal driving 14:1 is not that bad but at WOT that's lean... Anything over 13:1 on a N/A application is lean...
gregbar
With the APR you can adjust however you move the whole curve not just in one spot. If you want to reshape the curve then tune. WOT 12.7 AFR
schacher94gt
Alright thanks guys. Another question is I have a mail order SCT chip thats been burnt can i reflash that chip and use it again for my dyno tune?
