aftermarket fuel rail help
Maniak87
i am doing a 408 swap into my 94 cobra this winter and i am stuck on the fuel system
i am using a super victor EFI intake with a CHP intake elbow. i want to use the edelbrock fuel rails http://store.summitracing.com/partdetail.asp?autofilter=1&part=EDL-3620&N=700+311092+115&autoview=sku i got with the intake but i dont know how to get them to work with the stock fuel lines. i dont have a need for a sumped tank since i am not going to be running a huge amount of power (plus i already have an in tank 255 pump). it doesnt look like they make adapters for out cars to get the stock ford fittings to connect to the edelbrock rails.
these wont work because then i would have both male ends with no female.
http://www.uprproducts.com/shopping/shopexd.asp?id=253
i then found this but its an expensive option since i have to get a new external fuel pump as well.
http://www.glennsperformance.com/product_info.php?cPath=28&products_id=145&osCsid=419649eec0fe897e32586f8c0a56b21a
is my only real option the glenn's part or a sumped tank?
stang94X
you have to buy all the fittings and line separately to use the those fuel rails, it aint cheap, summit racing has all the stuff you need, you should have just bought the trick flow rail kit, it comes with rails, FPR, lines, all fittings and connects straight to the stock fuel lines
Maniak87
the rails came with the intake manifold (got it all with my motor used).
im hesitant to use that glenn's kit because of how much it would end up costing. i guess i can sell the edelbrock rails and go with the TF kit?
is this the kit u are talking about? http://store.summitracing.com/partdetail.asp?autofilter=1&part=TFS-51580001&N=700+4294908331+4294908282+4294924760+4294925239+400098+4294839074+115&autoview=sku
maybe i can get just the fittings from that kit since i have the rials and regulator.
stang94X
after buying all the fittings and lines needed with a new fuel pressure regulator if you dont already have one that will work those rails, you might as well just spend the money on a trick flow kit that comes with absolutely everything and works with stock fuel lines
GearGambler
Northeast PA
you need the female connections to the stock fuel lines (feed and return), and then connect those adapters to some flexible fuel line, with male AN fittings on the other side that go to the edelbrock rails right?
for the feed line
http://www.ronmorrisperformance.com/miva/merchant.mvc?Screen=PROD&Store_Code=rmp&Product_Code=9142
this one is for the return line
http://www.ronmorrisperformance.com/miva/merchant.mvc?Screen=PROD&Store_Code=rmp&Product_Code=9141
is that what you are looking for?
most of the stuff i saw out there is to connect aftermarket lines with the stock rails. didnt see much if anything to connect the stock lines to aftermarket rails.
Maniak87
