Due to a firmware glitch I had to replace my air ride controller. I thought I would break it out in a separate page and link that to my build page since its got a little long. My stomach has kept me out of the garage since I got it yesterday but I can do some work on the computer in between vomit sessions to get work on the display done. While I was disappointed to think of the work I needed to do it was going to allow me to finish the overhead console where the old display was mounted as I had other plans for it and never did finish it in the end. I also have a cnc now which makes it much easier to make really cool shit. The dispay is a really solid piece that is machined from aluminum and it could be simply stuck to the dash.
First I cut the piece of acrylic to go around the display. The only part of this that will be seen is a .05" line that will end up lit up similar to the way my switch panel looks.
The aluminum will be polished and you can see some of the paper on the back of the acrylic between the aluminum and the display. That part will light up blue.
The black abs piece above is shown backwards. I machined ridges in between the abs and the aluminum so that the aluminum will be held in place since this will be upside down as well as blocking any light from bleeding through.
The fake carbon fiber will not be staying. here you can see the line around the display that will light up shows as that orange/brown paper color. more to follow
