alternator bracket?
Turbo SN
is there anything i can use besides a stock one. my car has no accessories. i currently do not have a bracket. all input is great. thanks matt
LAFENATU
Carol Stream, IL...omg I lived there when I was little :rollinglaugh:
What are your intentions man. Why do you have no brackets?
T
Turbo SN
i bought the car as a roller. wiring harness out of it and no brackets. put a motor together with a little turbo and a dfi system. all i have are fox body brackets. the car has a tubular k member with a manual rack. only pulleys are alternator, water pump, and crank.
T
Turbo SN
will not work on a 94-95. already checked. i guess i am stuck with the stock one. if anyone has one for a fair price, let me know. thanks matt
T
Turbo SN
i don't have clearance to do so. i have a large radiator and electric fan. i have been told it won't fit.
95 svt cobra
so are you looking for the bracket that the alt mounts to? if so i have one, or are you looking for something more custom looking
T
Turbo SN
what else will i need to use this bracket as far as tensioner. basically i need to mount the alternator, water pump pulley, and crank pulley. is there any difference in the actual alternator or pulley for it?
MM Alexander
If you don't have any of the front dress and want to use the March Bracket. Why not just go with the Fox timing cover and water pump? Then you could use the Fox March Alternator bracket and the Fox front dress items are plentiful in JY's.
Just a thought.
ScottyDsntKnow
Change your timing cover/water pump over to the fox style and then get everything you need from the JY. Doing this and eventually the fox TB conversion opens up the world of aftermarket valve covers to you.
T
Turbo SN
i already did the intake change. i am just going to do the fox swap on the front of the engine.
