-:Antenna Delete:-
whiplash473
Northern IL
so i'm shaving the antenna on the mustang in the next few weeks but i'd like to come up with some solution that will let me keep an antenna..i've gotta shorty antenna right now so i'm not sure if i should mount it in the fender or what......any ideas/solutions/advice for this?
joekd
Ct
My solution
Looks like a retracted power antenna and if I ever want the OEM one back on it takes all of 5 seconds to switch
whiplash473
whiplash473
Northern IL
yeah i saw that when i was searching here..i would just leave it like i have it tho (8") if i was gonna do that......btw how's the reception with that anyways?
I ran mine side ways on the fender in my 95..
you got a pic by any chance rz?
Orange 94
Alberta Canada
I took the antenna completely out of the fender. now i have an antenna on the inside mounted on the top of the window on the passenger side with the wires running inside the pillar. Completely hidden except for a tiny black box at the top of the window inside.
g36 monkey
Orlando, Fl
They sell little strip antennas that could attach somewhere. [MENTION=11896]ttocs[/MENTION] would really be able to help you out here.
Orange 94
Alberta Canada
you can sort of see it in my picture. Its barely noticeable. its on the window snugged up against the headliner. The box is a a little thicker than my middle finger and about the same length.
Still get great radio reception btw
whiplash473
whiplash473
Northern IL
yeah same here..i'd just like to keep it just to have it.....i'll see what scott has to say (monkey's post) and also see what kinda room i have to work with after i do the wire tuck
EDIT: OJ - thats actually not bad but it would drive me nuts..i know it......good idea tho
Is it the wire waiting to get cut off when the door shuts?
Do a search for a strip-mount under-dash antenna. Work great, don't need to be seen.
Orange 94
Alberta Canada
NO NO! That wire is for the wideband. Will be taken out soon. The antenna wiring on the other side and is completely hidden! There only thing that can be seen is that little box. Sorry i didn't make that clear.
bhorne89
Kansas City, Mo.
I did what Orange did, I used to install car audio for a living, Best Buy sells an antenna for $6.99, it has 6 feet of wire on it, I mounted mine in the passenger side pillar, it fit perfectly and rna the wire down and over to the stereo. I have done this a lot when I worked there on peoples classic cars, or custom cars without an exteranlly mounted antenna. I have never had any reception issues by doing this, and it is completely hidden. I shaved mine as well. Hope this helps.
I started off installing at best buy back in '94 and I am fairly sure that even they the cheapest ant then sold was $15-20. Do you know which one is only $6 or was that cost on the part?
