torkmonster
- Joined
- Feb 10, 2008
- Messages
- 9
- Reaction score
- 0
I have a UPR anti sway bar.
Anyone use theirs on the street?
torkmonster said:Both on the rear! Should ride on rails that way!
Spd0Lit said:From what i have heard you have to unhook it on the street because it fights to keep the rear axle level with the car, so if you take a corner and a good amount of speed with it hooked up the the body will want to induce some roll but the bar is keeping it lined up with the axle and then kapow it snaps. I hope you understand the explanation.
bany95 said:The bar is be designed to flex under cornering, so it should be okay (assuming you bought quality parts, and installed them properly).
BUT if you were running soft rear springs, drag shocks, and a really stiff sway bar... you will apply more load to the sway bar than if you had the proper springs & dampers installed. But most guys who are canyon carvers don't use soft springs (hopefully).
Just my 0.02
SRT Handz said:torkmonster said:Both on the rear! Should ride on rails that way!
rides on rails :boink:
my96gtstang said:THAT IS SOO SICK
bany95 said:Handz, why two anti-roll bars instead of just one larger one (you can get up to a 1.25" OD x 0.250" wall sway bar from MM)?
bany95 said:And FYI the flowmaster tail pipes seem to work with a MM PHB.
bany95 said:I'll try to get some better pics of my setup this weekend, and start a new thread next week.
When I installed everything it looked fine, but when I was puting the car away this fall I noticed that it was rubbing a bit (on the axle I think).
