Anybody have experience with MM RUCA tool?
Daryl
SoCal
I’m going to replace the rear upper control arm bushings on my ‘95 Cobra. Are there any nuancesI should know about to accomplish this?
Any/all feedback to help is appreciated!
Wmac
Steeltown, Ontario
As per the instructions, lots of lube (anti seize) on the bolt threads. Maybe a squirt or 2 of WD40 on the old sleeves during removal and clean any residue from inside the axle housing ears. Lube the new sleeves.
Daryl
Daryl
SoCal
Ok, that’s exactly what I was hoping to hear. “Follow the directions and should work as advertised “! I watched the video and I sense that dousing them with WD-40 or any good penetrating oil (overnight then again couple hours before gettin after it) should make the whole thing go more easily.
Now I’ll have to decide if I want to wait for the MM order to be filled (no ETA) or cancel that part of the order and get rubber ones from NAPA which are readily available. I can be a bit impatient. Dilemma is: I want to get this all done before the engine gets rebuilt (also no ETA!) so I don’t want to procrastinate.
Wmac
Steeltown, Ontario
Yup, lots of penetrating oil now will only help. Bushing shell will be corroded to the axle housing mounts.
MM recommends rubber bushings only. I bought the motorsports kit and a pair from a supplier just to have an extra set. They turned out to be identical. Go figure. One set FRPP, one set AC Delco.
TrickVert
Woodland Park, CO
Buy the tool! It's worth every cent! Also, buy the NAPA rubber bushings. (They're the same as OEM.) That's one place you don't want poly.
Daryl
Daryl
SoCal
Today’s a good day!
I finally had 1/2 a day to dedicate to gettin under the car and tackling the darn RUCA bushings. And man, what a battle it turned out to be! I’m happy to say... I won! I got the passenger side done in only 4 hours!!! I’m thinking the driver side shouldn’t take as long now that I’ve figured out a couple of nuances about lining up the rear portion of the bracket that attaches to the melon.
Wmac
Steeltown, Ontario
All in a days work Daryl. Its just part of the hobby/addiction. Have a couple beers and tackle the other side tomorrow.
Haven't seen any updates on the 347 thread lately.
Daryl
Daryl
SoCal
04A6520A-80F2-4770-8466-BBC5E4AF0EB6.jpeg White95,
Yeah, it was a sum-bitch but it needed doing. In the long run, I’m glad I’m doing it.F038FD97-9A9F-4015-9BD5-112D7347D66E.jpeg
Daryl
Daryl
SoCal
wmac,
Nothing yet. I told myself I wouldn’t be “that guy” who called and bugged them weekly, and I haven’t. But I did call them back once a few weeks ago to confirm they will save and return all the stuff they are replacing. They are.
Based on the ballpark estimation of turn around time when I dropped it off, it “should be” end of this month to first week of February. Trust me, no one more anxious than me!
Wmac
Steeltown, Ontario
Daryl: I thought that control arm looked new, but your car is so clean underneath, so did not ask. Are you replacing both upper arms? Are they M/M?
What about the lowers?
Its money well spent. You will not regret this.
Daryl
Daryl
SoCal
Yes, replacing both upper control arms and they are from MM. I ordered the replacements because they came with the forward bushings pre-installed! I took the easier way out! Rubber bushings, not urethane, btw.
The adjustable lowers are on order from MM, but super delayed by COVID crap.
