anyone ever painted this?
dutch
The clear plastic lines bother me from some angles.. did anyone ever try to paint the upper parts of their headlights black? :dontknow: Just brainstormin'
GDTrumbo
Nashville, TN
I've thought many times of doing this. Looks good. Although, I would use high temp paint. The housings get pretty warm after some time with the lights on.
GT
dutch
dutch
the tape is a good idea Kev, so what it looks like for a few days :)
JerZeyStangz
Northern NJ
I think the problem is that you do not have the headlights all the way in the header panel (which holds the front end correctly). It's a sweet idea but if you just want that part of the headlight covered you have to screw the taps on the headlight in more.
DFG_magic
Kennesaw, GA
Thus messing up the aim of the headlights. Just aim them properly and do the tape/paint method. Electrical tape with an exactoknife/razor blade will take you far.
ReplicaR
If would probably be a good idea if you are running HID conversion. It would not give off as much glare.
GDTrumbo
Nashville, TN
If the edges of the headlight & the side marker don't match up though, it looks crappy there. Mine are flush with the side markers but the upper surfaces of the h'lights show some. Every '94-'98 SN95 I've looked at is like this.
GT
El_Diablo
GT
not nearly hot enough to need high temp, you'll be fine with a standard automotive grade paint
95opal
Did this a couple of years ago after when i saw 69clarks car like this. He actually gave me the strips of black vynl that I used to do it.I think every set of lights should be made this way. that top piece just dosent look right without it.
95opal
dutch said:
got a more close up pic of that?
this is all i have for now ill have to look and see if i can come up with a close up
switch96
Awesome pic! I'll have to find my tripod so I can do this when I shoot today.
