Anyone running RPM II with a stock hood or systemax
Urban Legend
Hey guys I got all my parts to go in afr 165 steeda #19 s-trim all I need to know is if a rpm II will fit under the stock hood? Thats the intake afr recommends
Thanks
95opal
It will depend on what valve covers you run. If the height of your valve covers force you to run a spacer, its going to be very close. I would say that if you need more than a 3/8" spacer, you will run into problems. 3/8 or less and you might just be touching the hood blanket. Thats best I can tell ya...
hottwheels04
It can be done, I run the stock hood with my trickflow track heat intake, I had to modify a few things to run the stock hood, I run a 95 truck block and had it decked and run a spacer and run stock valve covers and had the lower intake decked/ shaved .5 of a inch off to match the decked block,I also took off the stock hood blanket and took off the stock strut tower brace and drop motor mounts , so now the stock hood closes and has a good 1 inch or so of clerance, It just makes it by to close
rz5.0
Great state of TEXAS
I did remove the hood liner.. Clearance is minimal but enough to close.. Maybe 1/8 of a inch I closed it with a 1/2" wrench on top of intake but it was tight
I had system max head for a short time on there and it fit with a 1/2" spacer under the stock hood. Hardest part is just finding valve covers that will fit under the intake and not hit the lifters.
Jerry santos
