Anyone use this before?
badass98svt
None of that should effect the length the cable needs to be. They are all direct replacement parts, just more heavy duty.
Either you have a fox cable, or you need to try it again. Are you SURE you routed it correctly? If you go the wrong route with the cable, it'll be too short. I've seen it before.
Do you have the firewall adj screwed all the way into the firewall, as far as it'll go?
MustangChris
Aurora, CO
its 100% OEM. it was professionally installed, so they may have routed it wrong... i doubt it... it bolted up okay.
stock quadrant, stock cable, stock firewall unit.
Ive taken it off and put it on 3 or 4 times and dont ever remember having a problem like this before... maybe ill take a look at it tonight... i dono. lol. i figured it was the clutch....
badass98svt
From the firewall.... through the k-member above the point where the steering shaft goes into the steering rack, long loop then up and over the powersteering rack, and straight shot into the bellhousing. Make sure there isn't any kinks or sharp bends in it.
MustangChris
Aurora, CO
thanks :) ill look tonight... this is (as far as i know the first time that the cable has been ENTIRELY removed.... I've detached it at both ends before for different reasons, but this is the first time its been all the way off...
x182dan
Factory cable with 118k on it with fiore firewall adjuster and quadrant. No problems yet!!! Adjusted it once for my liking and its been the same way ever since.
mikey94gt
MustangChris said:
i want to order the UPR headlight knob... that will be the $15.00 i give to them... that will be it...
Called spec, they said to use the stock cable and quadrant. I was trying to call you and let you know. sorry about all the bs!!!
Hoseitdown
i have had 2 steeda cables.
broke the first one, and the second one the first day of install. so I went to ford and got one.
FORD FTW!!!!!
B
BlackCobra50
I bought one from autozone. I installed it, and it wouldnt go into gear... So I tried adjusting it and rerouting it a couple times and still wouldnt go in gear... so I was like wtf... I took it back out and realized that is was like 4 inches longer than the other one... I was so pissed! I took it back. Called Ford and they said $180 and they had to order it. I said f*ck that and went to advance auto parts, they had it in stock for 50 bucks, installed it and works perfect =)
MustangChris
Aurora, CO
the steeda one is the same as the summit racing one... i just put the stock one back in... i used steeda's quadrant thought, because putting the stock one in is a son-of-a-bleach..... . . :angry4:
anyways, the steeda quadrant lifted my clutch pedal up too... lol. i personally like the new position...
anyways, stock cable FTW.
calling steeda today to mail back their crap... it was even used.... its dirty... i mean... seriously?
Addermk2
mustangchris, the problem you were having with your cable not reaching is because you probably forgot to release the tension on your stock ADJUSTABLE quadrant
MustangChris
Aurora, CO
you're absolutely right...
at the end of the day, it was disassembled and i didnt want to go through the headache of the stock quadrant again... i want it, but i dont think i want it that bad... we'll see how i like the steeda one.
