Anyone using a Lightning MAF???
19mustang95
how did you get it to work with your harness...i have been told it wont plug into ours..so do i need to find one from a lighting and splice it into my harness or what? help would be greatly appreciated. :-*
ju015dd
tallahassee, fl
mine worked just fine, cobra is a 96 and it came off a 99 lighting. i think as long as it is 96 or newer you will have no prob. obdII
19mustang95
i asked the guy who is selling it and he said it wouldnt just plug in... :(
19mustang95
96, i just went ouside and checked, its a 6 pin connector..im guessing he misunderstood what i was talking about.
ju015dd
tallahassee, fl
you should be good to go i would think
G
GREG@SN95
Guest
WHY NOT TO UPGRADE YOUR MAF
Many people think they need to upgrade their MAF. The truth is you dont need a new MAF until the stock one is pegged. Its not so much as to what amount of hp will peg one, but the amount of air going through it. But as a rule of thumb, we will go with 400rwhp. Now Im not saying go out and buy a new one if you're at 400rwhp, you need to datalog the MAF counts and such to see if you need a new one. VERY rarely will someone with a NA car peg the stock MAF.
What does upgrading to a larger MAF do?
Basically it will lean you out and cause the car to run very poorly. As a result you will need to get the car retuned. If you dont, then the lean condition your new MAF causes will lead to a blown motor. Now after you get the new MAF and have the car retuned the gains are very minimal. So that makes your new MAF pointless.
Also, just as a side note, intakes with a bend before the MAF cause bad readings. So stay away from those too.
It gets into more detail here. And for those who dont know who Ed Clark is, he is a VERY reputable tuner at Steen Racing. http://forums.modulardepot.com/showthread.php?t=25092
Peter
I spliced it into my harness for my car, I think your car would have similar wiring.
SonicStang
I have a vortech and a lightning maf, too. It just plugs in. You might have to extend the wire, and get a power pipe because the stock vortech pipe doesn't really fit because the diameter is smaller.
Dlm75
