AODE to C4
94 DropTop
How do i do this? I have been told ill have problems cuz i have an electronic trans right now.
95stang5.o
ok here how i went about it i put a 5 speeed computer in and got it to stop surging idle and i put the c4 in and with 3.73 gear im about 3200 at 60 on the high way i made a plate the that bolts to my crossmember to to my trans cuz i dont know how to make a knew cross bember and i did this all on the budget cuz i blew my aode up and i bought the c4 for 30 bucks and it was built and it had lasted me 2 years knowso all to gether i spent like 150 on everything
G
GREG@SN95
Nice! Can't beat that for 150.
AODE is GARBAGE... C4 ftw
G
GREG@SN95
94 DropTop said:
well looks like i might go for an aode then
don't that would be a mistake...
either ditch the electric shift BS and go with the bullet proof C4...
or bolt in a 7r40w out of a 99+ mustang. Same trans, just stronger with lower 1rst and 2nd gears...
A new ECU can be gotten for 100 bucks at a junkyard..
trav_19
im doing this swap soon ....screw electronics everything is coming out of mine
Magic
Some time zone
He cant use the one from the 4.6 cars...different bellhousing pattern....
What he CAN do is, use the gear set and from the 4R70W and use it in an AOD(e) case along with good clutches/bands etc....a trans shop can do it....
Here is a link with lotsa great info on the AOD, AODE and 4R70W.....if its a street car that sees the highway, then I suggest you go thru this link...
http://www.tccoa.com/articles/tranny/#
