are these the right sfcs for 96 cobra?
joekd
Ct
I don't see why you would need to modify anything to use those
ProKiller
PA
i've never heard of having to modify the crossmember for any subframe regardless of year/make.
Steven
SC
96-98 use a bolt in cross member. The brackets that it bolts to actually bolts themselves through the subframes up front. So essentially when you go to weld the SFC's on, you find out there is a big bracket in your way on both sides. I just ordered a set of MM's. They advise you to cut the tabs out of the way and weld the whole bracket to the frame. Then place the connector on top of it and weld the notch tabbed portion to the side of the brackets. In a sense, you are just welding your cross member brackets and braces to the SFC's and getting rid of the bolts.
ProKiller
PA
interesting...learn something new everyday.
330CubeGt
I run tubular err thang
1997GT4.6
+1 well said.
96GTPlanB
