Are these the right size oil lines?
883cobra
Hartselle,Alabama
While I changed the oil in my car for the first time instead of having it done where I worked.I noticed the the two lines near the oil filter didnt look right to be the "factory" lines.They appear to be two big and not sealing up tight on the ends.I am guessing they direct oil to the oil cooler.Any one else replace these lines?if so what size should they be?They are to wore to read any size.Thank you
below are two pics to show.the purple arrows point to the lines.
Top side by oil filter
Lower section of lines
CC'S95GT
Hampton ,Ga.
You nailed it, those are oil cooler lines. Us lowly GT owners don't have that.
They do look like they need replaced or removed altogether.
Addermk2
Yep, Cobra oil cooler lines. They route coolant through the housing between the filter and block.
Addermk2
You can remove all that crap too... It's slightly better than useless, but doesn't really do much.
Canaryonvskf’s
