auto gt to 5 speed or 6 speed swap
justinschmidt1
wondering what it would cost to swap an auto to a 5 speed?....would it be much more expensive than rebuilding a broken auto?
96sohc
First off you need to decide what you really want; a built auto and a basic 5/6 speeds are two different things.
bigjohnson4.6gt
yes
voidfinger
well if your going to swap to a five speed, i got some things i need to unload that i was getting to do the swap. But it feel threw and i lost interest. Just message or answer back if you want some stuff
Hybridbird
If you spend money where you need it and save on other stuff by buying used stuff it's about even, I've done the math.Watch the boards and Ebay and you will get some deals.
voidfinger
yea i got some needed parts like pedal asy. and block plate. o and a pro 5.0 power tower and pro 5.0 knob :)
Darkcrime
how much for pedal assy and bpock plate?
I'm doing the 5spd swap (aod to t45)
voidfinger
i would like to get the money i put into it. let me look it up in a bit
I've seen complete auto to swap kits using a mixture of used/new parts from MPS for @$2000
Building an auto is also gonna cost a nice amount. A good TC will run you about $900, then doing a Jmod or shift kit or manual valvebody will add some more as will a oil cooler and getting a better oil pan (deeper with more capacity)
So it comes down to do you want to shift yourself or not?
96sohc
While the MPS kit is "complete", you can piece together your own swap for much less.
T's Convertible
