Auto to Manual Q's
98zzzz
Ive got the t45 and 4v in the gt which was an automatic car. The 4v computer, engine harness and trans harness are being used and are completely hooked up along with the pedals mounted in the car. Now, what about the clutch ignition switch? Will I need to swap the under dash harness? or is there a way to bypass the switch? or utilitize the auto electronics?
19mustang95
to my knowledge, all dash harnesses are the same between auto and manual cars, so it should have the plug for the harness. I've never had an auto, but i've never heard of them being different.
19mustang95
Just to add, it's quite easy to bypass the switch. All you need to do is to make a "jumper" that connects both slots in the plug. A regular sized fuse works perfectly for this. I did it one time to test if i had a bad clutch switch.
Jrgunn5150
The neutral safety switch? The plug is there, but you may need the little piece to go to it.
Or make a jumper as stated
