Battery Keeps dying
Black95
Hey all,
I have a problem with my 95 GT if I let the car sit overnight and don't start it the following day the battery is completely dead , can this be an alternator issue or something else, if I start the car even if I run it for 5 minutes the following day it's fine starts right up
What he said... The mach amps have been known to cause this problem. IF the car had the mach system it probably still has the factory amp under the radio. If that is the case you can pull the carpet back by the console on the drivers side and disconnect it. Its the metal box with all the holes in it, not the abs computer that is blue further in front.
