Battery selection...
Tillerman77
Willamette Valley, Oregon
If I hadn’t, I apologize. If I did, I’m happy to reiterate:
When I start the car up (doesn’t matter cold start or if I’ve been running it around town), it seems to struggle to turn over. Hard to describe in words, but I get a 3-stage “moan” then it
fires up. Kind of a “wuh-wuh-wuh..... bam”, turns over. But it’s such a low, pathetic struggle of a moan that drew my concern. So, the obvious places to look initially are the battery and the starter.
This is with the newly rebuilt engine - correct? If so, did it ever start differently since the rebuilt engine was installed?
take a video of it. There could be a couple of things under the wuh wuh wuh bang area depending on how you pronounce it.
Daryl
Daryl
Somis, CA
Tillerman,
No difference before or after the engine rebuild. Starts up same.
Daryl
Daryl
Somis, CA
Unfortunately, I think that’s the case. That being said though, wouldn’t that actually narrow down the culprits to either the battery or the starter?
Tillerman77
It would seem so. Have you tried getting a jump from another vehicle to see if it changes the starting behavior? That might help you figure out if it is your battery or not.
Daryl
Daryl
Somis, CA
Tillerman,
No, I haven’t but what would it tell me? If it starts up real quickly, what does that indicate? And if it starts the same, what would that mean?
Thanks for the idea. I’ll let you know...
Ooh, it’s intermission in the Avs/VGK game. Going now...!
And I’m back! Start up was pretty much identical with and without the jumper cables
so more current doesn't help it, that tells us your battery is ok. Could be the starter. If you don't have longtubes its not that hard to swap it out and find out but then if it ain't completely broke I don't want to get under the car myself.
Daryl
Daryl
Somis, CA
Ok,I’ll jack her up and have a look see. I’m pretty sure I don’t have long tube headers.
Daryl
Daryl
Somis, CA
Well, sometimes ya gotta look at the most obvious, simple thing. Kinda like in the movie “Slingblade” when he figures out the lawnmower ain’t running because “it ain’t got no gas!”
In the case of my battery… I installed the battery wrap and while I was at it, wire brushed the snot out of the cable hook ups and wiped the battery pays clean of gunk and build up.
F’g thing fires right up now!
Result!!
Addendum, completely unrelated:
I completely wasted a newer Camaro asshole in town today. Felt goooooood! Lit it up off the green, burned through the intersection, got a little sideways… never saw him again ++++
if you ever have the terminals hooked up and can move it just the slightest little bit it is not tight enough. When I was 17 I didn't put the terminal on tight enough and I could just BARELY wiggle it a little bit. I mean a couple of degrees either way was all it was but every 2-3 weeks I would have to pop the hood, wiggle the terminal enough till it had a semi-clean connection and gave enough juice to start it up.
Tillerman77
Result!!
A fine example of Occam's razor! Congratulations!!
Daryl
Daryl
Somis, CA
**UPDATE**
FWIW, it’s 10 months on since I replaced the car battery with a MotorCraft battery and I’ve had NO ISSUES AT ALL. I did do the insulation wrap to help against the heat of the engine, but the combination is working and problem solved!
Tillerman77
**UPDATE**
Good to hear. I have had good luck with both Motorcraft and NAPA Premium batteries in my fleet over the years.
do you have a battery charger that has a start function built in? If it does hook it up and see if just a couple of extra amps makes it turn faster. Like I said I have seen batteries test as good that were just on that point of going bad that it starts to have issues. If you don't have a charger like that just hook up some jumper cables and see if it does it still.
