Good point...Tony where you going to Chrome out your alternator ..for show or is it acting up and need testing ...and the belt you replaced a month ago didn't fix your problem?While you have the belt off, spin the accessories (water pump, alternator, etc.) to see if you have excessive drag. Cold be, something's binding up and ready to seize!
lmfao! just seen this!i'd pull the belt..clean the snots outta all the pulleys..then use a thick comet/water mix and go over the whole belt......squeeks drive me nuts......i'll fuggin pull over on the highway and fix a squeeky belt
