bent flywheel?
regulator_rt
i have an automatic 95 GT
the car's slammed and the streets here arnt really too kind to that...we got sum nasty speedbumps
and i hit 1 bad bump and i think i might've bent the flywheel. :BangHead:
is that possible?
and if it is will i be hearing that rattling gratting noise??
ram360
you'd have to crack the bellhousing first. Auto's use a flexplate.
LAFENATU
The plate is inside the bellhousing.
On the AODE the bellhousing is a part of the transmission, it is not sperate.
R
regulator_rt
okay,but i still cant pinpoint where is rattling is coming from, it not internal, it has to be towards where the tranny is sitting..any help with that?
Win
Kennesaw, Ga
+1 auto's have a flex plate
What are the symptoms your having???
Why are you thinking this???
If your hearing a rattling noise it can many numerous things.
Win
Kennesaw, Ga
Go take a look at your smog pipe. If you have a O/R pipe and someone didn't put it back on completely that could have fallen off or gotten garred loose and is causing a rattling.
R
regulator_rt
its a consistant rattle, but not consistant with the idle, and it comes and goes but never compleatly goes away
and its just noisy, its not messing with the performance of the car, but i dont want it to grow into a problem
ram360
if you have converters it could be those. If it just started happening after the speed bump incident crawl under that bad boy and look for some fresh metal. You'll see exactly what contacted w/ the pavement.
GDTrumbo
Nashville, TN
Do the auto cars have a removable inspection plate covering the lower front section of the flexplate/converter? If so, remove the inspection plate & check for damage to the plate. Drive the car w/o the plate in place and see if sound persists. Could be the speed bump made contact with the bottom edge of the plate.
I had one on my '69 Road Runner that drove me insane for a while. Found that I had simply installed it backwards.
GT
d_punch
could be a heat shield, when mine came loose the rattle would drive me nuts
R
regulator_rt
checked underneath the car and it ended up being the torque converter having sum loose bolts, tightened them up and the rattle was gone.
thanks for the tips and ill keep u guys posted with the stang's progress, im waitin on sum equal length shortys.
Win
Kennesaw, Ga
DUDE if your Conv had some loose bolts that was a hard hit i would check everything out...........
GT
I think if i remember correctly it is a rubber plug!!!!
R
regulator_rt
yea i inspected everything, i have a couple of dings in the H-pipe but thats about it, found out today that the previous owner had tken it apart, but did a half assed job on putting it back together, so the bolts walked out over time..thks aloot for the help.
R
regulator_rt
yeah for sure, ima get sum headers in, so wen i put those on ill locktite those bolts from the torque converter.
