best bang for the buck
essasin
Gears, GT40 heads and intake, nitrous, slicks if you are running the track, weight reduction. I'd personally get a nice exhaust note, drop the car, put some nice wheels, and enjoy driving the car.
mikey94gt
Gears, Nitrous, exhaust and a shifter, maybe some slicks. possibly a good intake manifold, definitely a ignition and coil, good tune up and a clutch.
CC'S95GT
Hampton ,Ga.
in another post you said your going turbo too, right?
gears make a difference when your boosting, but I am not quit sure which is optimum.
maybe 3:55's might be better.
dave1989
yea i plan on goin turbo im just looking to find good way to spend a couple hundred bucks before i do it
2002BLGT
Bedford VA
save the couple hundred till after the turbo , you will probably break something
dave1989
your right probably so i dont plan on runinn but 6 psi at first then 10 afterhead studs and and gaskets
x182dan
gears 4.10s FTW unless you plan on giving this car lots of power then I'd drop down a gear
teestang66
Do mods that will work with different future plans. turbo sounds good at first but what is ur budget for a split block?
It doesn't take much boost to split 5.0 liters w boost. Might want to build a good motor w decent heads and strong block before you boost it. My friends son split his block on second trip out w buddies in the car!!!!!!!!!!!!!!!!!
