BEST ENGINE OIL?
EVILSN
What engine oil do you guys run? I currently use valvoline 10w40. Would it be beneficial to switch to a racing oil?
Sent from my iPhone using My dick
Addermk2
Oil type and weight is highly dependent on power level, driving type, and bearing clearances.
None of which, have you provided.
EVILSN
EVILSN
Basically .0014 all the way around, 340hp, occasional driver but gets the breath beat out of it.
ranger56528
West central Mn
10-30 valvoline in the motor in the GT now but looking at running synthetic in the motor Im building now,think I'll go Royal Purple 5w-30. 5w due to the fact it will be used during the winter as a back up car and 30 due to the miles on the short block I'm using. Will see what kind of oil usage I'm getting and if it's more then I like ill try a 10-40 syn,better to start thin.
g36 monkey
Orlando, Fl
I did a lot of research and as far as oil "quality" goes, Amsoil seems to come out on top in that category.
Per the weights, I can't help you so much there.
with how much I had started to put in the car the past few years I drove it that I started doing nothing less then royal purple.
CC'S95GT
Hampton ,Ga.
clean oil is the best oil.
Amsoil, Royal Purpel are both great synhetics. But $$$$$ damn they're pricey. Sure you can go longer between oil changes and recoup some of the cost.
I use Castrol in all my cars. 95 Mustang- 240,000 miles origional motor, 99 Suburban- 250,000 miles origional motor, 89 toyota- changed the motor at 310,000 miles but not because or a worn out motor. For what ever reason it burnt a vlv and a getting a used freshly rebuilt motor was the same proce as rebuilding my head.
Carolinastang78
