better belt tensioner
mtang98 gt
Well I've been looking around for another company besides thump racing because I find that price outrageous...
I just need something that will prevent the belt slip from my shift kit..
Thanks for any help
mtang98 gt
mtang98 gt
Hmm that's not good..well is there an OEM style one that seems to hold up well?? Or maybe I should just get an inch shorter belt?
mtang98 gt
mtang98 gt
Well still wondern if I could go from a 98'' belt to a 97" to get some more tension
97stanger
like you said you could always go with a shorter belt. But I personally own a Thump Racing tensioner and theres a reason it is the price it is...its the best out there
joekd
Ct
Both the belt that was on my car and the GY one I replaced it with at 97.5", not sure if that is what you consider a 98" belt but this size works perfect and is silent on my car
mtang98 gt
mtang98 gt
Hmm maybe ill try that size then cause the one I bought from Napa is a 98"
joekd
Ct
If it helps the GY gatorback I used is part # 4060975
whiplash473
Northern IL
Tensioners have a solid pressure.....they don't increase or decrease depending on movement.....so a shorter belt isn't gonna change anything if you're having a tension problem
Sent from bored/stroked iPhone
mtang98 gt
mtang98 gt
Well the prblm I'm havin is that my shift kit shifts so hard it cause the belt to slip I'm not sure what I could do to stop that
