blew oil pan gasket out. help
ZachSav
so i had my car up in the air and noticed my oil pan gasket was forced out of the right side of my motor, im assuming bad pcv system. im going to put breathers on instead of the pcv system. could anything else cause this?
Win
Kennesaw, Ga
Yeah if the motor has some miles on it and someone saw the Gasket " Sweating" they could have tightened it up and squeezed it out. If it still seals and your not loosing any real consumption of oil you might want to leave it for a while till you wanna tackle the job. It's not a hard one just takes a little time.
birel21y
+1 Its a time consuming job for sure. Mine did it too after 16 yrs. The gasket "swells" and comes out a bit. its from 15 lbs or torque on a rubber gasket for all those years. The rubber breaks down.
Z
ZachSav
well ford has an updated pan gasket and bolts, its a cheap fix. im gonna tackle it next week sometime while im at work. no big deal
modo
Philadelphia, PA
if you put a breather on the valve cover MAKE SURE you put a cap on the nipple on the tb of the line that goes from the valve cover to the throttle body. (im assuming its the same on a sn95 as the foxes)... if you do not that is un-metered air
Paul
+1
Or just tap it and stick a pipe plug in there like I did. :)
