blew the plug right outa the head WTF
seth_96_gt
well wats up guys so i got a 96 gt with 97k on it well today i was just driving not even gettin on it and bam thought i blew my belt go and start lookin arounf sure as shit my plug was had blown the threads right out of the threads on the head has anyone ever heard of this happening??? if so how do i go about fixin it the motor is mostly stock besides a pi intake stock npi heads any help is greatly appreciated
Happens all the time!
You need to get a time cert to install.
Its more common on the Windsor PI heads but it will happen on Romeo too especially if a plug change was done and they were over tightened or loose. They can get loose by themselves and slowly back out then bam!
1slckgt
yea ive heard of this before it just randomly happens its happen to my friends ss and my friends mustang.but never heard of it strippin the head thats crazy. i recomend takin the head to a machine shop and seein what they can do.
seth_96_gt
wat do you figure price wise to fix it im sure the heads gotta come and get tapped...
Magic
Some time zone
It can be repaired in the car.
Around here, there is a guy that will come to the shop and fix the plug threads. Charges like 90-100$. This beats the hell out of ripping the engine apart or swapping in an engine.
Ask your local machine shop or repair shops. If they tell you "it cant be done in the car", keep looking!
Red 97
You can find a set of pi heads and cams for around 300. I'd swap those suckers.
Happened to my car a coupe years ago...I was at my girlfriends place at school...a couple hours from home, so I had to solve it quickly. I bought another spark plug...installed it in her parking lot the next day...and its been fine now 2 years later :dontknow:
Didn't get my head re-tapped or anything.
seth_96_gt
pi heads iv been thinkin of it something of it but times are tough bein laid off and no cash
seth_96_gt
if so wouldnt i need a longer plug with a hela coil wouldnt it sit higher out of the chamber
Paul
This can be done in the car without too much difficulty. If done correctly, nothing will change and everything will be back to normal. It's not that difficult.
WarHorse
Ive never heard of this, Thats crazy, good luck gettin it fixed hope its not too expensive.
US Soldier(stang 98)
Dixon IL
No you just put the hela coil on the new plug then run the plug into the hole. a hela ciol just gives you a lil wider thred. that should stop the plug from coming back out.
4.698gt
Like stated above get a time sert or heli coil or whatever you want to call it. Weld a rod to the piece that cleans up and preps the old threads for the insert to make life a little easier. Install helicoil and put your plug in. Don't worry about the shards of aluminum they will just burn up
Jerry santos
