Caliper ?
95DarkGreenGTS
Bossier City LA
hey i was going to put 01 GT calipers on my 95 Mustang. All I need is the Calipers Correct? I dont need the brakets if I remeber correctly. RIGHT? What do i need to make this work
ReplicaR
You need calipers, brackets, and correct banjo bolts for the brake lines. You will also have to grind off a little bit of the spindle to clear some space for the new two piston design, otherwise the pistons will hit the spindle.
ReplicaR
I got mine for 50 dollars 2 years ago. 75 is a pretty good deal as well, as long as everything works.
Jerry santos
