Cam size?
itsblue95
Louisville Kentucky
i am buying a set of AFR 185 heads for right now intil i start on my 351. i was just wondering what is the biggest cam i can fit with the stock 5.0 pistons? any help would be greatly appreciated
LAFENATU
Stock if you're lucky. Stock cam and 185's is gonna be real close.
I would still clay the heads to make sure.
itsblue95
itsblue95
Louisville Kentucky
im putting the AFR 185s on the stock 5.0 for now this is just intil i get around to build the 351.. trying to find out what size cam would go good with the stock 5.0 and AFR 185s
AFR says the 185s require piston notching so my guess is even the stock cam would be pushing it close. My guess is the 185s are going to want a pretty healthy cam, not something the stock pistons would be able to handle without some notching.
jpeister
Can anyone give me the stock info as far as lift and such for a stock 1995 Vert. Looking into getting a cam what I have right now is ( GT40 intake, BBK Shorty headers, Mac off road H-pipe, Flowmaster 40ser,) Looking to get cam throttle body and cold air intake..... Any help is awesome.....
94-427
ran a stock short block with AFR 185 and E-303 cam no problems picked up 1.2 on 1/4 times
rz5.0
Great state of TEXAS
i heard of people doing it but being really close over rev and there goes your valves. i have after market pistons and had big relieves but they didnt go back far enough. didnt know till i pulled the heads and saw were they were hittimg just bearly but they were hitting. so i just notched the pistons.
RIFTER11
Nashvegas
the OEM pistons have valve reliefs as cast ... they just need to be enlarged. I wanna say that there was a link on here where someone took the an old valve (same sizes as the heads he was puting on) and epoxyed a roloc disc to it. Chuck the valve into an air drill (or high speed cordless) and go to work. This can be done with the short block still in the engine bay, just be very particular about covering coolant and oil passages as well as a thoroughly cleaning up afterward. Someone please correct me if I am wrong.
BigTang
using the old valve is a PITA if you can't get the paper to stick to the valve. I used it for a guide to make an impression of what I needed to cut then I used an air sander to cut out the relief on the piston. Took about 15 mins a cylinder to do including checking and cleaning.
here's pics from when i did it. I came back and hit it w/ the air sander to knock down the sharpness and get it out closer to the cylinder wall and I laid the relief back some for more radial clearance.
of course I did this w/ my performer heads then swapped to the Z304 w/ the same 2.02 valves but the intake valve was moved so I lost a little clearance and couldn't run my cam 242/248 .612 and got pissed and just put the stocker in it.
itsblue95
itsblue95
Louisville Kentucky
Thanks for all the help guys I'll be running AFR 185s after I notch the piston what size cam should I run? I was wanting to run a tfs 1
BigTang
backwards is this question.
purchase heads. purchase a good cam that will mate well w/ those heads and your intake.
clay the pistons I prefer lime green playdoh, cause green's cool.
cut piston to give .100 clearance all the way around the valve(both valves), this includes the edge of the valve
if you cut it 1st its like saying hey i bought some tires what car should i buy to put these on.
