Camshaft question!
Witzy0070
Montana
Ok, so I am looking at camshafts for my H/C/I swap.
I will be using a Explorer upper and lower intake and brand new GT40 heads.
Now I have been debating over a E303, a Steeda #19, and this http://www.summitracing.com/parts/CCA-SK31-336-4/ which is what I'd like. How ever I do not know if it's too aggressive, the exhaust duration is significantly longer than the Steeda and Ford camshafts.
All I am looking for is peoples opinions and info.
LAFENATU
You can't use that cam. It is a flat cam, not a Hydraulic Roller.
LAFENATU
The TFS Stage 1 cam works well with GT40 heads. Make sure you have upgraded valve springs on the heads with an aftermarket cam.
Witzy0070
Witzy0070
Montana
Well I prefer the specs of that cam more than the others. Going to go for that one. Thanks!
blackpony
i wouldnt recommend the steeda cam. I have it and have not been impressed with it... I second the trickflow stage 1...
birel21y
Im running the Crane 2040 PowerMax Cam (same spec as E303) in my explorer longblock im building right now. With 1.7 rockers its a lot of lift, almost too much. Here is my setup:
http://cranecams.com/?show=browseParts&lvl=2&prt=5&Vehicle_Type=Auto&Cylinders=8&Engine_Make=FORD-MERCURY&Year=1994&Engine_Size=302%20C.I.&partNumber=444231&partType=camshaft
2000 Explorer long block
GT40 "p" Heads
light intake port job (gasket match heads, gaskets, and intake)
Billet true dual adjustable roller gears/chain
Cam timing advanced 2*
Flow Kooler High Vol. water pump
Melling high Vol. oil pump
Proform Pickup
Proform 7 qt. oil pan
Felpro 1 pc. silicone oil pan gasket
FMS lifters
FMS pushrods
Crane cams 1.7 rockers
Prothane Poly engine mounts
ARP bolts throughout
FMS black/red valve covers
TFS track heat intake
1" phenolic spacer
24 lb injectors
TFS valve spring kit w/ chromoly retainers
BBK 75mm TB
Summit 75mm MAF
Aluminum U/D pullies
Centerforce DF clutch
Findanza Aluminum F/W
Witzy0070
Witzy0070
Montana
Right on, thanks guys. However I think I will stick with the 1.6 rockers. But, what length and diameter pushrods do GT40 heads use? The roller rocker set I am buying, I don't think it includes new ones...
LAFENATU
You have to buy an adjustable pushrod checker. Measure them and then order.
I'd have to say the opposite lol. I think the #19 is a really nice cam.
two95s
If your thinking about buying the iron gt40s save your money! They aren't much better than the e7s. As far as cams, look at Comps xe series.
yeah it has some lift but the duration is huge for heads that don't flow much. How much are you looking to spend on heads?
jthorn9
+1 I paid $980 shipped for my X303 heads and they were rebuilt/cleaned so they were practically new.
