sn95 bullitt
They say I need camber bolts to get it aligned right. I thought the the caster camber plates would put in back to the right specs.
you mounted them backwards...
How do I tell if there in race mode?On the MM, the smaller plates that the strut goes through can be swapped from left to right. The large plates are side specific. One combo is race, one is street. The race config does not go more than -1.x positive on camber.
A lot of J&M stuff is very similar to MM, so check that.
Couldn't find a set of instructions on their website: http://www.hotpart.com/
Maybe see if you can email or call someone.
