car running super rich ( help )
B
black96gts
it was doin the samething with the aeromative fpr so i put the stock fpr back nothing changed
B
black96gts
but alot of people have told me that it should be ruuning good without a tune with the 255 fuel pump
silver 4.6
Guest
if theres an upside, its not running lean and granding your engine, so you have plenty of time to figure this out before something blows.
B
black96gts
it even turn off by itself cus its too much gas too rich all u see is black smoke and the car wont start .. i have to disconnect the plug from the fuel pump and reconnected it .. back to start the car , the if u put new spark plugs and u drive the car for 15 min u have to put a new set of spark plugs and the car wont accelerate right .... i will have to take the risk and get a tune to see if that fix the problem
Jrgunn5150
You need to check the fuel pressure at the rail, either your regulator or FMU is screwed up.
Jrgunn5150
black96gts said:
whats the fmu?????
Fuel Management Unit, it bumps teh fuel pressure in response to boost. If your car is boosted and untuned, and not blown up, it must have one.
Jrgunn5150
Then you have serious issues.
Exactly what DOES your car have? It can't run stock injectors with a blower and no FMU, and it can't run bigger injectors without a tune.
Tell me exactly, what injectors, what MAF, what tune are you running with your procharger?
B
black96gts
ok last month i took my car to a dyno and my tuner made a program tu start the car with 39 injectors .. mafia .. and a aeromative fuelpressure regulator .... the first pass car made 328rwhp at 4k rpm cus i had the stock fuel pump ... but i could drive the car fine .. so i put a 255 pump last week and at that moment the car start having the problem .. so i took everything back to factory .. stock injectors fpr and took off the mafia and still have the same problem :dontknow: :angry7:
2002BLGT
Bedford VA
did nobody read line 3 of my earlier reply ,
CHECK THE FUEL RETURN LINE AT THE GAS TANK , YOU PROBABLY PINCHED IT CLOSED WHEN YOU PUT THE TANK BACK UNDER THE CAR , THIS WILL SPIKE THE FUEL PRESSURE
Jrgunn5150
You still need to check the pressure at the rail, determine what it is, then go about diagnosing the problem.
2002BLGT
Bedford VA
I agree , but if all he changed is the fuel pump imma bet my money this is the problem and his fuel pressure is probably around 80-85 psi
Jrgunn5150
You're probably right, but the fastest way to find out is to check the pressure at the rails, like I told him two days ago.
