Car started acting a a**..Got a few codes
RD95gt
Last week or so i noticed the CEL started coming on and off.Few days between no cel at all the pops on for a few seconds and goes out again.Last night while cruizein i noticed in 5th gear low rpm(like 1700 or so) car kinda had a little jerking goin on that it hasent done before.CEL was coming on and off alot last night and it even died at the redlight a few times.So this morning i went outside and counted the cel light flashes after jumping out the connector and this is what ive came up with.
117 coolant temp circuit below min voltage/indicates above 245 degrees.
Car was not overheating and the temp is fine/normal Change sensor????
172 Heat o2 lean right side
Cars got about 130,000 or so on it. Should i replace or solve the rest of my problems first?
556 Primary fuel pump circuit failure..
Filters been changed recently..UMMMM i guess ill go get a guage and check pressure? Car does run.
565 canister purge circuit failure..
This code has been in the car since i purchace it
Any advice is much appreiciated.. Mods are in sig.
R
RD95gt
Ok.Car decided not to start after work today.Turns out i had some bad batt connections and i need some new terminals.May have had alot to do with it.Cleaned them.put em back on a seems to be running much better.Tomarrow im gonna go get some new ones.Sometimes it the small stuff that makes it look like you have a huge problem......
