car wont run...help!!!!!!!
DH95GT
hit a pot hole in my car and it immediately shut off and wont start now...i checked the fuel shut of switch and it didnt shut it off and i checked my fuel pump fuse and it is fine...i then took the old pump out of my car and checked the voltage to the plug on my fuel pump and it was only at 1 V...does anyone know what could be wrong or what the voltage to that plug should be? any help would be great. thanks oh and i put a new pump on the plug and it wont work either fyi thanks
Dylan
ck the ccrm. there's a f.p. relay in it. your haynes manual should give you the color codes for the wires
SableGT
I had the same problem once and the small ground wire that attaches just in front of the battery was broke.
DH95GT
I found the problem!!! The CCRM was jared loose and as soon as i plugged it back in the pump took off!!!! Thank you everyone for your help it is such a relief that it will run now!!!!!!!!THANKS AGAIN
