94darkhorse
When I go to start the car I can put the key in the on position and all accessories will be on just fine, radio works, lights on the inside work and everything. Then when I go to turn it over and everything just goes off and starts flickering until I turn the key off. I can hear the relay in the ccrm clicking when I try to start it as well. I havent had air in the car for a year now and I havent tried to investigate why but I wanted to check out how hard it would be to check the cps and noticed that my compressor has a leak of some sort, I was wondering if the oil has caused an issue with the cps or if there might be another issue with the car, hopefully not the pcm. Car is a 96 cobra and has 14k miles and is only driven when its decent out.
