Caster/Camber plates and rattles from front strut area
94Cobra347
I have the steeda 3 bolt caster/camber plates on my 94 cobra and a set of edelbrock ias struts and new poly spring isos. I have an annoying rattle from the caster/camber plate area that I hear when I hit bumps. Is this rattle common with caster/camber plates? My steeda directions state that you can change the configuration of the metal spacers to adjust for different ride heights and strut heights. I'm trying to decide if I should take it all apart or if this rattling is normal. It isn't real loud or very noticeable, but just enough to bug me. Thanks for any input.
Steve-Oh
39°57′9"N 75°9'48"W
It might not even be from that area... Check the brakes and see if the "anti-rattle" clips are worn/even there. If it bugs you that bad order brakes from Ford directly. They were the quietest pad I have ever had on there and they NEVER rattled. They cost a pretty penny though.
Jerry santos
