caster/camber plates?
MuscleInc1320
i always hear about ppl changing their caster and camber plates but why? what are the benefits of changing to some aftermarket ones?
Suspect
ATL
copied from MM..
Whether your Mustang is driven on the street, or pushed to the limit on a racetrack, a proper alignment is essential. A good front-end alignment provides greater stability, better steering response, increased front grip, and longer tire life. There are no drawbacks to having the proper alignment! The Maximum Motorsports Caster/Camber Plates are engineered to provide the widest range of alignment settings possible. This ensures that a proper alignment can be achieved for any type of driving.
Lowered Mustangs
When a Mustang is lowered it loses available suspension travel and may bottom-out frequently. The lower ride height will also result in excessive negative camber, which often causes uneven tire wear. The MM Caster/Camber Plates have the adjustment capability to allow an alignment to correct any excessive negative camber caused by lowering. The MM C/C Plates will also allow regaining lost suspension travel, which will improve both performance and ride comfort
