CCRM Trouble
1SLO GT
We just swaped motors into a different car, both cars are 95GT cars, both are 5 speeds as well, the problem we are having is that when you turn the key forward, in the fule pump prime postion, the CCRM makes a loud buzzung sound, and the fuel pump sounds VERY weak, we used the CCRM that came out of the other car which was running and driving 2 days ago, we also tried another CCRM with the same result, any ideas?????
Bad ground? The relays inside may not be making good gnd connection thus the buzzing. Make sure there is no paint or crud under the connections.
SN95_JP
I had the same problem.. I changed the CCRM, fuel pump, relays and the same problem... the problem was the PIP try with it... with me that solved the problem...
Suspect
ATL
+1 had the same buzzing when i dropped the new motor in. check ur grounds.
lhc_mustang
Same thing the other day. This is a swap too, i clipped a wire and it turned out to be a ground for the CCRM.
Staff online
