Check Engine Light Came On - help!
belber095
Ithaca, NY
car was running fine, still is. check engine light came on as i went down a hill. i didn't notice any noises or anything. my coolant looks low, but that's the only thing that i could think of. any help would be appreciated. gonna take it over to autozone tomorrow to pull the codes.
CC'S95GT
Hampton ,Ga.
low coolant would throw a low coolant light.
have you broke out the trusty paper clip and pulled codes?
Could be any number of things like O2's, dirty MAf, Dizzy, muffler bearing, low blinker fluid, flux capaciter.
9838stang
Minneapolis,MN
unless you have a faulty o2 sensor.... it might have read one bank was too rich or too lean since there wasnt and back pressure and rear the fresh air that came back in the exhaust...
9838stang
Minneapolis,MN
it also could be since the exhaust is more"free" that the air coming into the motor seems to be restricted... might be a dirty MAF, it's readings we set at one point and changed a bit more the next...
belber095
belber095
Ithaca, NY
i can't find a paperclip.. lol. i guess i'll just wait til tomorrow to get them pulled. i won't be driving it until tomorrow to get over to the autozone so i should be ok til then right? my best guess is that the backpressure's confusing either the MAF or the o2 sensors. thanks for the replies guys. i'll keep you all updated when i get home tomorrow.
Check all your fluids and make sure you're not running low on anything. Tranny, oil, coolant...
And I don't know about the area you live in, but over here Autozone stopped pulling codes in like '06..
Slykin
Tyler, Texas
I pulled my check engine light out of my dash ages ago haha. Good luck though, i'm sure it's nothing major.
belber095
belber095
Ithaca, NY
They still do it here haha. Nice service to have. I might just change all my fluids. I haven't since I've had the car so its probably about time anyways.
tapatalkin'
9838stang
Minneapolis,MN
Here, Autozone and oreilly let you pull the code but they have the ob2 code readers that will not shut the code off...
joekd
Ct
Until you have the codes we wont be any help
ODB2 readers are cheap now, I have a handheld one that I use for quick scans and truning off CEL if needed, I have the scanguage in the mustang so I can even turn off CEL on the fly if I want
belber095
belber095
Ithaca, NY
Came back as evac and emissions. Assuming its from backpressure making the o2 sensors think my cars running lean.
tapatalkin'
9838stang
Minneapolis,MN
i would go back and ask for a code. it could be a number of things... like a O2 sensor going bad, a MAF sensor going bad or being dirty, IAT sensor, TBpostion sensor, i would ask for a code so you are not wasting your time here and there.
