clutch cable breaking
max5ive8
Troy, Michigan, United States
Anyone running a heavier clutch having the clutch cable fail? I have a Fidanza 4.3 which is a kevlar/ceramic combination single plate clutch and it is pretty stiff. Apparently too stiff for the clutch cable because I have been through three of them. Twice breaking at the clutch fork and most recently breaking the plastic end that is inserted into the firewall adjustment. Any recommendations? Thanks in advance.
mod46stang
i had the same problem but my problem was the throw out bearing sticking but i was running the wrong quadrant my fix was a new throw out bearing and a quick release quadrant and none adjustment cable and firewall adjuster and im runing a heavy stage 3 macloude clutch throw out bearing only lasted half a year the first time the cable was stretching and caused the bearing to fail
