96dkgreengt
- Joined
- Apr 23, 2008
- Messages
- 190
- Reaction score
- 0
i had my clutch replaced about 5000 miles ago with a centerforce clutch, and about 1000 miles ago my throwout bearing started chatterings when the clutch was depressed. yesterday (9-1-10) i got in my car to go to the store and i was going to shift into second and my clutch pedal felt weird and my clutch went out (wasnt able to get into second gear or any gear).. i let the car sit in neutral for alittle bit then tried to go into gears ago still nothing, so i pumped the clutch a few times and kept trying to get in gear, and eventually it went and i drove off, worked fine for alittle bit then did the same thing again where it wouldnt go into gear again, so i played with it alittle again and it worked fine then i parked it and havnt touched it today..
i read in other clutch threads that centerforce makes crappy tob's and i just purchased a ford oem tob since i herd they are better to use then any aftermarket ones, which im going to be installing this upcoming weekend, just wanted to know if anyone else had this problem and what could the solution be if u dont think its the tob making it do that??
