Clutch/trans probleum
spdtrip
Over the winter I had a friend-certified mechanic put a new clutch in my T5.Well it shifts great except high rpm 3rd gear shifts
and the clutch pedal vibrates during normal or fast exceleration I know its still new but something just seams off what do you guys think?
BTW the clutch is an Anderson hi-rev king cobra.
Addermk2
get under there and check your driveshaft bolts
just because he's a certified mechanic, doesnt mean he isnt human. and Humans makes mistakes!
Did you put a fire wall adjuster in it or an adj cable at the same time?
If yes then ck the tension on the cable. it might be too loose
IceMan
Also check your damper. They are known to go bad. Make sure the rubber ring has not "walked" on you.
94RockinGT306
it sounds like its either a loose driveshaft , bad u-joints(which will usually cause a "clunk" whenever you engage and disengage the clutch), or he put the driveshaft back in with the transmission not all tightened up and then tightened everything up and its in a bind, it should always be put in last, except for the ehaust of course. If thats not it i would pull the tranny back out and double check everything, it could be the cable or the throwout bearing.
