cobra cam
Starsky74
i have a set of 95 cobra heads and rockers i plan to put on my 94 gt this weekend. i also have the cam to match and was wondering should i swap it while im in it
or leave the stock gt cam? i have no way to tune it right now either. i have heard some bad things about the cobra cam, any help is appreciated!!
I don't think a Cobra cam is worth the swap, better off going with a lil aftermarket cam. Cobra computer isn't really going to help you unless you have 24lb injectors.
Addermk2
run a TFS1 or a comp cams xe276hr(check PTV)
you're swapping on ok heads, might as well run a decent cam
wytstang
With now way to tune it I just just run the stock cam retarded 5* and mill the heads 0.015" and replace the springs if they are old.
LAFENATU
If you can't afford another cam and only have the option of the Cobra OR the stock GT cam...You'll make more power with a stock gt cam.
