Cobra maf??
RonBurgandy
Pikeville, Nc
Can I use a 95 cobra maf on my 95? I don't see why I couldn't. And what size injectors did the cobra come with
Brought to you by Pornhub
R
RonBurgandy
Pikeville, Nc
No tune yet hoping the cobra is plug and play since I will be running 24 when my hci is done up
ScottyDsntKnow
Cobra and GT MAF are literally identical down to the part numbers. The Cobra had 24# injectors that is true but the Cobra computer's fuel tables are tuned to compensate for the 24# injectors which is the correct way to do injectors instead of installing a "calibrated" (hacked) maf.
Addermk2
So much sloppy information in this thread... The whole thing should be deleted.
God its a good thing I never became a mod.
Addermk2
Would you care to enlighten us..
I'm too tired to give more than half of a shit.
Good cause I'm about to ditch the lmaf and grab a cobra and I'm running 24 lb inj anyway
Why are you going to waste your money on a MAF from a cobra. It is literally the same part number as what came in your GT from the factory. It WILL NOT help you run 24# injectors.
R
RonBurgandy
Pikeville, Nc
When I'm done with my hci I will be running 24# and I am possibly trading my lmaf. I was told it was a 70mm 95 cobra maf so I thought it was plug and play and would be easier to use than the lmaf. And I think tge lmaf may be over kill for my hci. After all I only have a 70-75 mm tb
Musturd
Get a tune... Keith addermk2 could burn you a chip to sort out the issues , but whoever told you the cobra maf is different.... You should just stop listening to that guy.
Addermk2
If you want a Cobra MAF that bad, ill trade you mine.
R
RonBurgandy
Pikeville, Nc
Ok ill just keep it then if I need a tune anyway. And idk I bad mouthed addermk2 earlier so I may be on his bad side lol
