codes
just a 98 gt
ok my car just threw a p0303 and a p0171 code i know misfire in 3rd cylinder and lean in bank 1 what would cause this car has new plugs and fuel filter good gas new tps the maf is clean what else yall think could it be any info will help
J
just a 98 gt
this is not the blue car in my sig its another car i have its bone stock except a x-pipe but like i said new plugs new tps new fuel filter new gas i checked the coil packs they seem to be working im thinking its the fuel pump idk but im trying to get this car going for my lil sis so any help would be nice
Blind
vacuum leak on the intake manifold most likely, unmetered air is getting in.
J
just a 98 gt
well see the car starts fine and after about 4 secs or so it starts to blubber and sounds like its missing i was just under the car and one of the O2s is broke and not hooked up and its on the bank 1 side and the other O2 on the same side is black as hell idk if that would cause that and as im driving the car it misses really bad but after im driving for a while it starts to act a lil better but once i lay into the gas after about 4500 rpms it looses power and i let off and the car goes crazy and jumps and jerks and stuff and once i stop it idels at like 600 rpms and acts like it wants to die
Blind
fix the O2 but running better after it gets warm is a classic intake manifold vacuum leak symptom.
J
just a 98 gt
ok man ill look at it here in a lil bit after i get some food and ill let ya know what i find out thanks for the info
