comp cams composite, box
red95
does the comp cams composite box fit 94-95 and if so how much hp, is anyone running this setup
R
red95
Re: comp cams composite box
didnt get a reply from anyone, iam talking about the comp cams upper intake manifold box that bolts to the stock lower mani please i need some advice
BigTang
only one i've seen was for a GT40 lower. Its similar to the cartek breadbox. you need a big motor or a lot of RPM to take advantage of it.
white95
Apex Junky
Admin
Prairieville, LA
Summit sells a Comp Polymer box for stock lower intakes. to use it on a sn95, i'm almost certain you'll need a throttle body adapter elbow.
R
red95
do you think i would have to use an egr spacer as well, im asking because i have never seen this setup on a 94-95
94 DropTop
Your not going to help yourself with this unless you have some form of forced induction, or alot of power.
R
red95
anyone else out there in mustang land have an opinion on this :evil5:
BigTang
what set up are you putting it on? if its going on a stock long block you're better off w/ the stock intake.
R
red95
this is the plan as of right now afr 165s steeda 19 cam and the box, but may just say f%$# it and drop a termi motor, im asking all these questions cause every stang shop where i live only messes with the 64-73 cars.
LAFENATU
AFR 165's and Steeda 19 cam stop making power around 6000 RPM.
The box is going to start making power around 3000rpm and probably go up to around 7500rpm when you push it to the limits. The heads and cam do not work with that Box intake..
