converter efficiency test results are in ... what do you see (besides obvious)?
Wes8398
After yet another failed emissions test, I had an efficiency test done on my cats. Looks like I definitely need new cats, but I wanted to see if anyone noticed any other abnormalities from the test readings. If there are indications of other issues rather than just the cats, please point it out to me. If you think it's just a matter of replacing the cats, let me know that too.
Efficiency Test Numbers
Pre-Cat
RPM - 1287
HC ppm - 163
CO% - 0.48
CO2% - 13.90
O2% - 0.93
NO ppm - 1534
A/F ratio - 15.00
Post-Cat
RPM - 1213
HC ppm - 134
CO% - 0.41
CO2% - 11.80
O2% - 3.80
NO ppm - 1306
A/F ratio - 17.43
Also, when it comes to cats - is there any downside (besides cost) to running a metallic core cat vs a ceramic core? Would you suggest one over the other?
Also, here are my emissions test results from a few weeks ago, in case it helps any:
40 km/h test
HC PPM - Limit 55 - Reading 102 - FAIL
CO% - Limit 0.31 - Reading 0.44 - FAIL
NO PPM - Limit 408 - Reading - 1315 - FAIL
RPM - 1273
Dilution - 1273
Curb Idle test
HC PPM - Limit 200 - Reading 85 - PASS
CO% - Limit 1.0 - Reading 0.10 - PASS
RPM - 671
Dilution - 13.99
W
Wes8398
Anyone have anything else to offer? Should I go ahead and install new cats, or does it look like there's more wrong than just the cats? What about my question about cat construction - metallic core? Ceramic core? Is it worth doubling price for a CARB certified cat, or is OBD II certification good enough?
W
Wes8398
That's a given, I'm going to install new ones. But one of my concerns is that the car isn't running right to begin with. Rather than "mask" a problem with the cats, I'd like to make sure it's running right too, ya know? Also, I don't want to install cats with the car running in a condition that's going to quickly foul the new cats either.
im not an expert, but aside from running rich and being old, i dont know what would fould up cats...
the fact taht you have PI Intake and Cams may upset your A/F ratio. ahve you been tuned?
W
Wes8398
I've not gotten a tune and I really don't want to do so either. I know it would be beneficial to the upgrades I have, but nobody does a "canned tune" for a PI cam/intake swap, so I'd not only have to drop $400 into a tuner, but another large sum of money into dyno time. No thanks.
Running rich burns out cats, I know that from experience. haha But what exactly is a rich condition? Is my a/f ratio (listed above) bad?
im not ... knowlegeable enough to properly read all that information. i dont remember if a larger, or smaller number means you are rich.
rich means that there is too much fuel in your combustion chamber at the time of combustion. this washes your cylinder walls dry of oil over time increasing wear-and-tear and obviously removing the motors protection...
my car runs rich at top end, which is common for NPIs (esp. in CO lol) but im not sure about your car, your set up, and i dont know enough about cars to tell you what EVERYTHING at the top says...
AaRoN
King Post Whore
Elevated HC and CO tailpipe emissions are often symptoms of a fouled converter or a faulty air supply. Converters don't just plug up or die for no good reason. Prolonged overheating or short term severe overheating are the leading causes of catalytic converter plugging. The problem is often fouled or misfiring spark plugs, or a burned exhaust valve that leaks compression and allows unburned fuel to pass through the combustion chamber into the exhaust. To diagnose a plugged catalytic converter, you can check intake vacuum or exhaust backpressure. To check intake vacuum, connect a vacuum gauge to a vacuum port on the intake manifold. Start the engine and watch the vacuum reading at idle. Then increase RPM's to about 2500 and hold it there. Normal vacuum at idle for most engines should be 18 to 22 inches Hg.
When was your last tune up (plugs, wires, coil packs, etc.)? Normal maintenance issues must be addressed. Also, do you have any CEL's?
uncltrvlnmatt
Pa.
What Aaron said. Plus don't get cats for a carb certified cats, get the cats for OBD2.
I know you said you don't want to get a tune, but with the PI intake, PI cams, You may be overfueling. Over time that could cause cat problems.
Lightning Struck
simple fix, YOU NEED A TUNE. End of story, the intake and cams has thrown a monkey wrench into the a/f mapping so you need a tune to correct it. I did the same on my old 98 and the tune took care of everything.
W
Wes8398
Thanks for the info. Since I took off the stock mid pipe 2+ years ago, I've had 2 different aftermarket mid pipes on my car - both were purchased used, so I really don't know what condition the cats were in (age, mileage, etc) before installation. When I swapped over to this Basanni pipe a few weeks ago, the UPR pipe I had on previously wasn't plugged. One side was totally blown out and hollow, and the other side appeared ok but I figured it was probably crap too so I tossed the pipe. This Basanni pipe appeared to be in great condition so I was hoping the cats were still good, but learned after this efficiency test that they're no good as well. So yes, I totally agree that cats don't foul for no reason, but I can't honestly say that my car has fouled any cats since I never knew their true condition when they were installed on the car.
As for the last tune up - I'm always doing that stuff on time or ahead of time. It got all new plugs (Autolite's - 2 ranges colder than stock as suggested to me by Johnny Langton over at Modular Depot years ago) and wires about 2 years ago when the PI cams and intake were done. Coil packs are still originals but seem to be doing the job just fine. It had a fresh oil change before the last Etest too; I do those at every 5,000 kilometers or less.
Why not CARB certified cats? Wouldn't they be the best ones? Or is it a waste of money when an OBD II certified cat should work just as well at a fraction of the price? And what about ceramic vs metallic core? I'm thinkin' metallic core might be my best option since it can withstand a bit more heat and general abuse...?
Also, if she was overfueling I would think that would have shown up in my A/F ratio reading (among other readings) above, no? My A/F readings of 15:1 and 17:1 are actually showing that I'm running a little LEAN rather than rich. I'm not arguing that a tune wouldn't do me well, but .... read below, I don't want to be too redundant...
I appreciate your advice, but seriously, it's too easy to just say "get a tune and everything will be solved". I know a tune would probably solve all this emissions crap for me (and also yeild me better gains from the mods I've done) - I knew it before the first person ever suggested it to me, and I still know it after the hundredth person has suggested it to me. BUT a tune isn't the ONLY answer here - it's just the easiest one to suggest (and also the most expensive one). Before I did the PI cams and intake I did a TON of reasearch among all the top Mustang forums (including this one of course!). I knew all the write-ups like the back of my hand and I also got in touch with a number of people who had personally done the swap and could tell me first hand what they experienced. From that I can assure you that the majority of people I talked to who installed PI cams and a PI intake did NOT need to get a tune in order to have their car run up-to-snuff, including from an emissions standpoint.
I'm certainly not arguing that a tune would solve my problems, but I'm just saying that I'm sure I can get my car running correctly via other means which wont cost near as much. A tune is going to cost me, say $400 for the actual tuner. Fair enough. But I've called/asked around and nobody does "canned tunes" for PI cam/intake swapped NPI's, so that means dyno time on top of that. The best local price I got (from Steeda in Milton, Ontario) was going to be like $700 for the tuner and 3 custom tunes. Sorry, but that's too much for me man.
All I want to do is know that my engine's running the way it should be. If it is (according to the numbers I've provided) than I'll just slap a couple well-made, dependable, NEW cats on there and hopefully pass the sniffer test and be off to the races. If it's not running right and other things need to be fixed, I want to do that stuff before I go and throw $300 worth of new cats on it just to foul/ruin them because the engine's not running right - ya know?
ruler
dyno sessions down here are 30 bucks for 3 pulls or 50buckd for an in house tuner session. 350 gets you a custom 2 position tune with dyno time. 700 seems a bit extreme but steeda can charge whatever they want
dang, ruler you get cheep tunes.
60$ for 3 pulls here in denver or 120 an hour. or 150 an hour for a tune with a 2 hour minumum
ruler
we have tons of speed shops. The tampa area has about 4 awd dynos and 20-25 regular ones. The ford dealers have some out when shelby or roush are in town selling mustangs. I am scared of them right now after popping twice. They hadnt even gotten to the nitrous yet either. Why would you never drive a car without cats? I picked up 16whp getting rid of em.
well you are in a rare group.
kenne bell did a test and they lost 0 HP on a 750 HP mustang by adding cats.
i aws reading a tuner magazine and they tested a civic with a turbo (turbos are a little bit mroe sensitive to back pressure than N/A mind you.)
they started with (lets say 200 because i cant remember what the exact number was) with out cats.
then they added an OEM cat and they dropped down to 190 HP
then tehy added a high flow cat and went back up to 199.
(i dont remember the exact numbers, but they lost 1 HP with a high-flow aftermarket cat and i remember they lost 10 HP with the OEM)
i dont have to worry about the ticket from driving without them
i dont have to worry about the impound from driving without them
i dont have to swap exhaust every few years for emmissions
im not smogging up the very air i later breath in
i have the ability to run o2 sensors instead of "Rich-B****es" a.k.a. MIL eliminators.
they litterally harm me in no way shape or form by having them. if i lose 1 HP, i promise i wont notice. the only thing they can do is make my life easier.
I've honestly NEVER heard of 16 WHEEL horsepower from a cat delete.... ive seen with my own eyes 5 WRHP. and i was drop-dead astonished.... 16 is mind-boggling.
