converter efficiency test results are in ... what do you see (besides obvious)?
AaRoN
King Post Whore
Lightning Struck said:
simple fix, YOU NEED A TUNE. End of story, the intake and cams has thrown a monkey wrench into the a/f mapping so you need a tune to correct it. I did the same on my old 98 and the tune took care of everything.
Our computers are pretty resilient, putting on PI cams/intake won't cause enough problems to warrant HAVING to get a tune.
ruler
mine were removed for an aftermarket x pipe so that might have had a lil bit to do with it. I can see your point though. I just hate the way cars sound with them and I always figured there was more of a power loss. I might have to look into them if we ever have emissions laws down here.
W
Wes8398
ruler said:
dyno sessions down here are 30 bucks for 3 pulls or 50buckd for an in house tuner session. 350 gets you a custom 2 position tune with dyno time. 700 seems a bit extreme but steeda can charge whatever they want
With your price of $350 for the tune and dyno time, plus the $400 to buy the tuner itself, $700 doesn't seem all that extreme even by your standards...?
Thanks for your input.
Just to stay on track:
Wes8398 said:
AaRoN said:
Elevated HC and CO tailpipe emissions are often symptoms of a fouled converter or a faulty air supply. Converters don't just plug up or die for no good reason. Prolonged overheating or short term severe overheating are the leading causes of catalytic converter plugging. The problem is often fouled or misfiring spark plugs, or a burned exhaust valve that leaks compression and allows unburned fuel to pass through the combustion chamber into the exhaust. To diagnose a plugged catalytic converter, you can check intake vacuum or exhaust backpressure. To check intake vacuum, connect a vacuum gauge to a vacuum port on the intake manifold. Start the engine and watch the vacuum reading at idle. Then increase RPM's to about 2500 and hold it there. Normal vacuum at idle for most engines should be 18 to 22 inches Hg.
When was your last tune up (plugs, wires, coil packs, etc.)? Normal maintenance issues must be addressed. Also, do you have any CEL's?
Thanks for the info. Since I took off the stock mid pipe 2+ years ago, I've had 2 different aftermarket mid pipes on my car - both were purchased used, so I really don't know what condition the cats were in (age, mileage, etc) before installation. When I swapped over to this Basanni pipe a few weeks ago, the UPR pipe I had on previously wasn't plugged. One side was totally blown out and hollow, and the other side appeared ok but I figured it was probably crap too so I tossed the pipe. This Basanni pipe appeared to be in great condition so I was hoping the cats were still good, but learned after this efficiency test that they're no good as well. So yes, I totally agree that cats don't foul for no reason, but I can't honestly say that my car has fouled any cats since I never knew their true condition when they were installed on the car.
As for the last tune up - I'm always doing that stuff on time or ahead of time. It got all new plugs (Autolite's - 2 ranges colder than stock as suggested to me by Johnny Langton over at Modular Depot years ago) and wires about 2 years ago when the PI cams and intake were done. Coil packs are still originals but seem to be doing the job just fine. It had a fresh oil change before the last Etest too; I do those at every 5,000 kilometers or less.
uncltrvlnmatt said:
What Aaron said. Plus don't get cats for a carb certified cats, get the cats for OBD2.
I know you said you don't want to get a tune, but with the PI intake, PI cams, You may be overfueling. Over time that could cause cat problems.
Why not CARB certified cats? Wouldn't they be the best ones? Or is it a waste of money when an OBD II certified cat should work just as well at a fraction of the price? And what about ceramic vs metallic core? I'm thinkin' metallic core might be my best option since it can withstand a bit more heat and general abuse...?
Also, if she was overfueling I would think that would have shown up in my A/F ratio reading (among other readings) above, no? My A/F readings of 15:1 and 17:1 are actually showing that I'm running a little LEAN rather than rich. I'm not arguing that a tune wouldn't do me well, but .... read below, I don't want to be too redundant...
I appreciate your advice, but seriously, it's too easy to just say "get a tune and everything will be solved". I know a tune would probably solve all this emissions crap for me (and also yeild me better gains from the mods I've done) - I knew it before the first person ever suggested it to me, and I still know it after the hundredth person has suggested it to me. BUT a tune isn't the ONLY answer here - it's just the easiest one to suggest (and also the most expensive one). Before I did the PI cams and intake I did a TON of reasearch among all the top Mustang forums (including this one of course!). I knew all the write-ups like the back of my hand and I also got in touch with a number of people who had personally done the swap and could tell me first hand what they experienced. From that I can assure you that the majority of people I talked to who installed PI cams and a PI intake did NOT need to get a tune in order to have their car run up-to-snuff, including from an emissions standpoint.
I'm certainly not arguing that a tune would solve my problems, but I'm just saying that I'm sure I can get my car running correctly via other means which wont cost near as much. A tune is going to cost me, say $400 for the actual tuner. Fair enough. But I've called/asked around and nobody does "canned tunes" for PI cam/intake swapped NPI's, so that means dyno time on top of that. The best local price I got (from Steeda in Milton, Ontario) was going to be like $700 for the tuner and 3 custom tunes. Sorry, but that's too much for me man.
All I want to do is know that my engine's running the way it should be. If it is (according to the numbers I've provided) than I'll just slap a couple well-made, dependable, NEW cats on there and hopefully pass the sniffer test and be off to the races. If it's not running right and other things need to be fixed, I want to do that stuff before I go and throw $300 worth of new cats on it just to foul/ruin them because the engine's not running right - ya know?
ruler
300 covers the cost of the out of box or custom tune. 50 covers the dyno time. 350 is a lot less than 700.
W
Wes8398
Thanks for the quick math lesson...I needed it. lol So do you get a tuner (ie an SCT XCal II) with that too? 'Cause that's $400 of the $700 price I'm getting from Steeda, as I explained. Maybe I'm under the wrong impression that I HAVE to buy the tuner with the tune. If they'd allow me to just pay for the dyno time and not have to actually purchase a tuner, then I'd definitely be in a more reasonable price range. I'm under the impression that I have to purchase the physical tuner as well as the dyno time though.
Anyway, I'm going to get a set of new metallic core'd cats and see where those get me. If I'm still failing with new cats, there's obviously something else wrong and I'll have to investigate further.
ruler
I am using a custom tune not a sct xcal. I have always found the canned tunes to be a little weak compared to custom ones. Mine goes on the dyno soon and this is the first session I get to watch (im off for the summer) so I will be more informed monday or tuesday when I go. I will try to find out what program he is using and contact information so you can ask questions. With the sct you wont need a dyno just answer the pop up questions and go. there is no 300 dollar fee for tuning a handheld. The 300-400 will cover the cost of whatever tune you want then you only need pay for the dyno time. The tuner makes money on the sale of the tuner and the time on the machine.
I am learning a lot about this process as well so please correct me if I am wrong I just thought your prices were really high. I am only custom tuning because I have a healthy shot of go go juice on mine and I dont need to go over 390whp for the sake of my rear end or my transmission. I also dont think my heads (unported pi) will flow much more.
W
Wes8398
Thanks for the info. Just to be clear, you have custom tunes but you didn't have to buy an actual handheld tuner unit like an Xcal II or Diablo? Like I said last time, I have always been under the impression that you have to have one of those units (at the cost of $400) in order to even have a shop tune you at all. I'll have to call around and look a little further into this I guess. If I can go into a shop and just pay for the dyno time and receive a few custom tunes, I'm all over that. But the dyno time PLUS the cost of one of those handheld units would be getting kinda pricey.
ruler
yeah I get ya. The dyno tune I just purchased does not require a handheld. I also have upgraded from 19lb to 30lb injectors and my tuner is using my stock maf. What makes mine a little interesting is I have an old 5.0 style throttle body (had to use it with the edlebrock intake manifold) and an IAC off of a lincon. there are pictures in my introduction thread "noob with a problem".
